Ga door naar hoofdinhoud
PRS Guitar Pickups Replacement
Wat je nodig hebt
  1. PRS Guitar Pickups Replacement, Pickups: stap 1, afbeelding 1 van 2 PRS Guitar Pickups Replacement, Pickups: stap 1, afbeelding 2 van 2
    • Loosen all of the strings until they can be pulled out of the tuners.
    • Pull the strings through the bridge and out of the back side of the guitar.
  2. PRS Guitar Pickups Replacement: stap 2, afbeelding 1 van 2 PRS Guitar Pickups Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips head screwdriver, unscrew the back plate, revealing the pickup wiring.
  3. PRS Guitar Pickups Replacement: stap 3, afbeelding 1 van 1
    • Take note of the wiring before desoldering the wires.
    • Begin desoldering the pickup wires.
    • Take care when soldering, as the tip is very hot.
  4. PRS Guitar Pickups Replacement: stap 4, afbeelding 1 van 2 PRS Guitar Pickups Replacement: stap 4, afbeelding 2 van 2
    • Turn the guitar face up and unscrew both of the pickups.
    • Take the pickups out of the guitar.
  5. PRS Guitar Pickups Replacement: stap 5, afbeelding 1 van 2 PRS Guitar Pickups Replacement: stap 5, afbeelding 2 van 2
    • Refer to the wiring arrangements you took note of as well as the wiring manual that came with your new pickups.
    • Run the new pickups back through the guitar with the wires guided through the back plate.
    • Carefully begin soldering the new pickup wires back together.
  6. PRS Guitar Pickups Replacement: stap 6, afbeelding 1 van 1
    • This is a good opportunity to clean the guitar.
    • Begin restringing the guitar with new strings of your preference.
    • Using a string/wire cutter and cut excess strings from tuners.
Eindstreep
Nathan Kevil
141 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 898
