Wat je nodig hebt
Open the memory protection
Remove gently the rear cover
When re-assembly take care to the thin tabs
This connector is directly to the board
This Flex connector need to be unplug
The 321 battery is there
You can add some thermal glue to fix the battery
I did it with a small piece of scotch
Bijna klaar!
To re-assembly your device follow the step backward
Conclusie
Met dank aan deze vertalers:
fr en
100%
Bertrand PIGEARD helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
