Inleiding
This guide will teach you how to use the soldering technique to remove the desired LED from the logic board and replace it with a new LED. Be careful when soldering because there is chance of damaging the controller.
Wat je nodig hebt
Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
Remove the logic board from the controller casing by lifting up and pulling out.
Één andere persoon heeft deze handleiding voltooid.
