Ga door naar hoofdinhoud
PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement
Wat je nodig hebt
  1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement, Joysticks: stap 1, afbeelding 1 van 1
    • Remove the two 11 mm screws from the back of the controller using a Phillips #0 screwdriver.
    • Remove the five 8 mm screws from the back of the controller using a Phillips #0 screwdriver.
  2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover from the controller and set it aside.
  3. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 3, afbeelding 1 van 1
    • Remove the circuit board from the front casing.
    • Be cautious of disconnecting the vibration motors which are attached by thin wires.
  4. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 4, afbeelding 1 van 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 4, afbeelding 2 van 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 4, afbeelding 3 van 3
    • Wiggle and pull the joystick until it comes off of the circuit board.
  5. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 5, afbeelding 1 van 2 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 5, afbeelding 2 van 2
    • Place the new joystick into position and press until the joystick makes a click.
  6. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 6, afbeelding 1 van 1
    • Place the circuit board and vibration motors back into the front casing.
  7. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 7, afbeelding 1 van 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 7, afbeelding 2 van 3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: stap 7, afbeelding 3 van 3
    • Place the back cover into position.
    • Reinsert the two 11 mm screws into the back of the controller using a Phillips #0 screwdriver.
    • Reinsert the five 8 mm screws into the back of the controller using a Phillips #0 screwdriver.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 77
Altijd: 2,649
