Ga door naar hoofdinhoud
PDP Afterglow Wired Xbox 360 Controller Cable Replacement
Wat je nodig hebt
  1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: stap 1, afbeelding 1 van 2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: stap 1, afbeelding 2 van 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: stap 2, afbeelding 1 van 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: stap 3, afbeelding 1 van 1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: stap 4, afbeelding 1 van 2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: stap 4, afbeelding 2 van 2
    • Remove the logic board by lifting up on the logic board and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: stap 5, afbeelding 1 van 1
    • The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
  6. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: stap 6, afbeelding 1 van 1
    • The soldering iron is very hot and can harm you or the device if used incorrectly.
    • Desolder the four pins.
  7. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: stap 7, afbeelding 1 van 1
    • Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jayson Norcross
283 Reputatie
1 Handleiding geschreven
IUPUI, Team 3-1, Harley Fall 2015 Lid van IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Leden
5 handleidingen geschreven
4 opmerkingen
where can I find a replacement cable to perform this precedure with?
Aaron English - Antwoord
yes!! i would like to know too.. i have been searching for long time for that cable
sokratis162 -
Android cable
Wayne -
U can use a old Android cable
Wayne - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 86
Altijd: 7,023
