Ga door naar hoofdinhoud
PDP Afterglow Fener Speaker Replacement
Wat je nodig hebt
  1. PDP Afterglow Fener Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 PDP Afterglow Fener Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 PDP Afterglow Fener Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps.
    • Remove the wire connected in the red box by gently pulling it off.
  2. PDP Afterglow Fener Speaker Replacement: stap 2, afbeelding 1 van 3 PDP Afterglow Fener Speaker Replacement: stap 2, afbeelding 2 van 3 PDP Afterglow Fener Speaker Replacement: stap 2, afbeelding 3 van 3
    • Take your soldering iron and unsolder the wire from the speaker.
    • The red square is the left tip and the orange square is the right tip.
    • Before wiring your new speaker in, clean the left and right tips with your soldering iron.
Conclusie
Thomas Williams
512 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,589
