Ga door naar hoofdinhoud
PDP Afterglow Fener Battery Replacement
Wat je nodig hebt
  1. PDP Afterglow Fener Battery Replacement, Battery: stap 1, afbeelding 1 van 2 PDP Afterglow Fener Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    Purchased the battery…plug doesn't fit and battery is too big to fit in the headset
    josey thompson - Antwoord
  2. PDP Afterglow Fener Battery Replacement: stap 2, afbeelding 1 van 2 PDP Afterglow Fener Battery Replacement: stap 2, afbeelding 2 van 2
    • This shows what your device looks like on the inside behind the part that you just removed from the headset.
    • In the red square is the connection between the battery and the headset.
    • Gently pull the wires that are connected to the white part in the red square.
    • Now that your battery is not connected to anything you can take it out of the headset.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Murat Terzi
215 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Lid van UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
3 Leden
10 handleidingen geschreven
1Gids Commentaar
Broke the headset while doing this “easy process” don’t listen to this method.
Daniel Sumida - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 7,546
