Ga door naar hoofdinhoud
Oven Heating Element Replacement
Wat je nodig hebt
  1. Oven Heating Element Replacement, Element: stap 1, afbeelding 1 van 1
    • Before purchasing your replacement element, make sure it matches the size of the first element.
    • The element may not fit inside the stove if it is not the appropriate size.
  2. Oven Heating Element Replacement: stap 2, afbeelding 1 van 2 Oven Heating Element Replacement: stap 2, afbeelding 2 van 2
    • Go to your electrical panel and turn off the power to the stove.
    • WARNING: Do NOT attempt any of these next steps with the power on.
  3. Oven Heating Element Replacement: stap 3, afbeelding 1 van 2 Oven Heating Element Replacement: stap 3, afbeelding 2 van 2
    • Open the oven door and unscrew the 5 mm Robertson head screws that keep the element in place.
    • In most cases, there will be two or three screws to remove.
    • Make sure you check the screws thoroughly in case there are more.
  4. Oven Heating Element Replacement: stap 4, afbeelding 1 van 3 Oven Heating Element Replacement: stap 4, afbeelding 2 van 3 Oven Heating Element Replacement: stap 4, afbeelding 3 van 3
    • Using your voltmeter, place it on the two wires to make sure there is no electrical current.
    • Gently pull out the element two or three inches to expose the connecting wires.
  5. Oven Heating Element Replacement: stap 5, afbeelding 1 van 3 Oven Heating Element Replacement: stap 5, afbeelding 2 van 3 Oven Heating Element Replacement: stap 5, afbeelding 3 van 3
    • Mark down the coloured wires and how they are connected. You will need to match them by color when you reconnect the element.
    • It may be helpful to take a photo of the element with the wires still connected. This will make reconnecting it easier.
    • Remove the screws holding the wires in place.
  6. Oven Heating Element Replacement: stap 6, afbeelding 1 van 1
    • Remove the damaged element from the stove. It should slide out easily.
    • If possible, try to locate where the damage on the element took place for future reference.
    • Begin installing the new element.
  7. Oven Heating Element Replacement: stap 7, afbeelding 1 van 2 Oven Heating Element Replacement: stap 7, afbeelding 2 van 2
    • Connect the power wires by matching the same color as the original element. (Refer to Step 5 for more information.)
    • Gently re-insert the element back into the stove opening.
    • Refasten the two screws at the front to secure the element in place.
  8. Oven Heating Element Replacement: stap 8, afbeelding 1 van 1
    • Close the oven door and reset the power through the electrical panel.
  9. Oven Heating Element Replacement: stap 9, afbeelding 1 van 1
    • Turn the power on and turn the oven on to make sure the element is functioning properly.
    • There may be some smoke and an odor coming from the baking element because of the protective coating. This is normal.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Alex Costantino
226 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 161
Altijd: 3,016
