Inleiding
If you have broken your Ovation Guitar string, use this guide to help you learn how to replace the string step by step. In this guide, you will learn how to not only replace the string, but learn how to implement a technique to prevent further guitar string breakage. Before using this guide, make sure inspect on how many strings are broken and if you have the correct strings.
Wat je nodig hebt
Place the guitar neck where you can easily identify the broken string.
Bijna klaar!
Eindstreep
