Ga door naar hoofdinhoud
Ottlite PL-0094 Touch Switch Hack
Wat je nodig hebt
  1. Ottlite PL-0094  Touch Switch Hack, Disassemble: stap 1, afbeelding 1 van 1
    • Place the lamp horizontally on a work surface
    • Unscrew the two screws above the control panel that hold the upper and lower parts of the lamp together
    • Slide up the control panel to remove
    • Unscrew the two screws that hold the power board in place
    • Use a soldering iron to gently melt the two plastic studs that hold the touch sensor circuit board in place
    • Remove the touch sensor button. It's not really an electrical or mechanical button; it's just decorative.
    • Install a small fender washer, machine screw and nut. Drill a small hole in the center of the control panel where the touch sensor button is placed.
    • Drill out the bottom plastic stud for the touch sensor circuit board mount.
    • Replace the touch sensor circuit board.
    • Use a small machine screw and nylon nut to secure the touch sensor circuit board.
    • Be sure the conductive foam is making contact with the screw and nut that is holding the fender washer.
    • Re-install the power circuit board
    • Re-assemble the lamp.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Wayne Seltzer
1.841 Reputatie
10 handleidingen geschreven
Boulder U-Fix-It Clinic Lid van Boulder U-Fix-It Clinic
Community
1 Lid
20 handleidingen geschreven
20Gids Commentaar
wayne i found this outtlight in the trash i tried to buy a switch of course there are none, anyway found your post and thought i would give it a try ..and it works thank you for spending time sharing the fix howie
Howard Fitzner - Antwoord Deel
Glad the fixed worked for you, Howie!
- Wayne
Boulder U-Fix-It Clinic [http://boulderufixiticlinic.org]
Wayne Seltzer - Deel
Once you take the circuit board off of being mounted is there a way to test to make sure the light so works? We can't tell if the circuit board is the problem or not.
Jaclyn - Antwoord Deel
If you touch the conductive foam attached to the circuit board, you should be able to turn the lamp on/off/dim.
Thank you for your helpful guide. I am new to repair and stuck on the 5th step --the two plastic studs that hold the touch sensor circuit board in place--because I can not locate the two plastic studs. When I look behind sensor board, I only see a small white plastic square in the center above a grey round piece of fabric. One end of the white plastic square is attached to the sensor board and the other is attached white plastic housing and it moves in when pressed --is that one stud? I do not see the second stud. thank you. Sue.
sue byrce - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 29
Afgelopen 30 dagen: 132
Altijd: 7,081
