Ga door naar hoofdinhoud
Oster Expressbake CKSTBRTW20 Inner Chamber Replacement
Wat je nodig hebt
  1. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Top Panel Removal: stap 1, afbeelding 1 van 1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 2, afbeelding 1 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 2, afbeelding 2 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 2, afbeelding 3 van 3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 3, afbeelding 1 van 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 4, afbeelding 1 van 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 4, afbeelding 2 van 2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: stap 5, afbeelding 1 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: stap 5, afbeelding 2 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement, Inner Chamber: stap 5, afbeelding 3 van 3
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 6, afbeelding 1 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 6, afbeelding 2 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 6, afbeelding 3 van 3
    • Remove the four 11mm Phillips #1 screws holding from the guard and inner lining.
    • Remove small rectangular guard from bottom of liner
  7. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 7, afbeelding 1 van 1
    • Remove the inner liner.
    • The inner liner will be connected to the outer chamber with wires.
  8. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 8, afbeelding 1 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 8, afbeelding 2 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 8, afbeelding 3 van 3
    • Disconnect the red wires from the inner liner.
  9. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 9, afbeelding 1 van 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 9, afbeelding 2 van 2
    • Remove the single 11mm Phillips #1 screw thats holding and inner lining in place.
  10. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 10, afbeelding 1 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 10, afbeelding 2 van 3 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 10, afbeelding 3 van 3
    • Use a spudger to push out the connector found on the inner lining.
  11. Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 11, afbeelding 1 van 2 Oster Expressbake CKSTBRTW20 Inner Chamber Replacement: stap 11, afbeelding 2 van 2
    • Remove lining.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Megan Saunders
701 Reputatie
5 handleidingen geschreven
USF Tampa, Team S7-G5, Passmore Spring 2018 Lid van USF Tampa, Team S7-G5, Passmore Spring 2018
USFT-PASSMORE-S18S7G5
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 476
