Ga door naar hoofdinhoud
Oster Blend-N-Go My Blend Blade Assembly Seal Replacement
Wat je nodig hebt
  1. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: stap 1, afbeelding 1 van 2 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: stap 1, afbeelding 2 van 2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: stap 2, afbeelding 1 van 3 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: stap 2, afbeelding 2 van 3 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: stap 2, afbeelding 3 van 3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly: stap 3, afbeelding 1 van 1
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly Seal: stap 4, afbeelding 1 van 1
    • After separating the blade assembly from the blender bottle, position the plastic opening tool on either side of the seal in the blade assembly.
    • Wedge tool between seal and seal seat wall.
  5. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: stap 5, afbeelding 1 van 1
    • Gently pry the seal up while lifting seal out of the seal seat.
  6. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: stap 6, afbeelding 1 van 2 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: stap 6, afbeelding 2 van 2
    • Place and press the new seal into seal seat with finger.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Paul Long
710 Reputatie
4 handleidingen geschreven
USF Tampa, Team 12-6, Blackwell Fall 2015 Lid van USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 1,906
