Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
