Ga door naar hoofdinhoud
Oster 3905 Retractable Cord Replacement
Wat je nodig hebt
  1. Oster 3905 Retractable Cord Replacement, Slot Levers: stap 1, afbeelding 1 van 1
    • Firmly grip your hand around the slot lever.
  2. Oster 3905 Retractable Cord Replacement: stap 2, afbeelding 1 van 1
    • Stabilize the toaster by placing your hand on top.
  3. Oster 3905 Retractable Cord Replacement: stap 3, afbeelding 1 van 2 Oster 3905 Retractable Cord Replacement: stap 3, afbeelding 2 van 2
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
  4. Oster 3905 Retractable Cord Replacement: stap 4, afbeelding 1 van 1
    • Both slot levers can be removed.
  5. Oster 3905 Retractable Cord Replacement, Outer Shell: stap 5, afbeelding 1 van 1
    • Place the toaster upside down so the bottom is facing the ceiling.
  6. Oster 3905 Retractable Cord Replacement: stap 6, afbeelding 1 van 2 Oster 3905 Retractable Cord Replacement: stap 6, afbeelding 2 van 2
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
  7. Oster 3905 Retractable Cord Replacement: stap 7, afbeelding 1 van 1
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
  8. Oster 3905 Retractable Cord Replacement: stap 8, afbeelding 1 van 1
    • Place the toaster right side up.
  9. Oster 3905 Retractable Cord Replacement: stap 9, afbeelding 1 van 2 Oster 3905 Retractable Cord Replacement: stap 9, afbeelding 2 van 2
    • Grab the outer shell firmly and pull up towards the face of the toaster.
  10. Oster 3905 Retractable Cord Replacement: stap 10, afbeelding 1 van 1
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
  11. Oster 3905 Retractable Cord Replacement: stap 11, afbeelding 1 van 3 Oster 3905 Retractable Cord Replacement: stap 11, afbeelding 2 van 3 Oster 3905 Retractable Cord Replacement: stap 11, afbeelding 3 van 3
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
  12. Oster 3905 Retractable Cord Replacement: stap 12, afbeelding 1 van 2 Oster 3905 Retractable Cord Replacement: stap 12, afbeelding 2 van 2
    • Take out the grey “cancel” and “bagel” buttons from the shell.
  13. Oster 3905 Retractable Cord Replacement, Retractable Cord: stap 13, afbeelding 1 van 1
    • Rotate the toaster so that the back is facing towards you.
  14. Oster 3905 Retractable Cord Replacement: stap 14, afbeelding 1 van 2 Oster 3905 Retractable Cord Replacement: stap 14, afbeelding 2 van 2
    • Use the PH#1 bit to remove one 8mm screw located above the wire on the casing.
    • Then use the same screw bit to remove two 10mm screws found at the bottom.
  15. Oster 3905 Retractable Cord Replacement: stap 15, afbeelding 1 van 2 Oster 3905 Retractable Cord Replacement: stap 15, afbeelding 2 van 2
    • Using the metal spudger, pry next to the black clip found at the base of the toaster and the casing.
    • Push down to separate the casing from the toaster.
  16. Oster 3905 Retractable Cord Replacement: stap 16, afbeelding 1 van 2 Oster 3905 Retractable Cord Replacement: stap 16, afbeelding 2 van 2
    • Gently tilt the casing towards the toaster as you pull up from the base.
  17. Oster 3905 Retractable Cord Replacement: stap 17, afbeelding 1 van 1
    • Use the PH#1 bit to remove the three 8mm screws located on the back side of the casing.
  18. Oster 3905 Retractable Cord Replacement: stap 18, afbeelding 1 van 2 Oster 3905 Retractable Cord Replacement: stap 18, afbeelding 2 van 2
    • When opening the casing a metal spring may suddenly pop out.
    • Use the metal spudger to pry open the two halves of the casing.
    • If you are having some trouble only using the metal spudger do not be afraid of using your fingers to pry the casing apart.
  19. Oster 3905 Retractable Cord Replacement: stap 19, afbeelding 1 van 3 Oster 3905 Retractable Cord Replacement: stap 19, afbeelding 2 van 3 Oster 3905 Retractable Cord Replacement: stap 19, afbeelding 3 van 3
    • Carefully remove the spool keeping your fingers on either side of the casing.
    • Tape down the metal spring to keep it from unraveling out of place.
  20. Oster 3905 Retractable Cord Replacement: stap 20, afbeelding 1 van 3 Oster 3905 Retractable Cord Replacement: stap 20, afbeelding 2 van 3 Oster 3905 Retractable Cord Replacement: stap 20, afbeelding 3 van 3
    • Carefully unwind the power cord from the spool.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Adam Dierkes
140 Reputatie
1 Handleiding geschreven
CSU Fullerton, Team 2-1, Bruce Fall 2016 Lid van CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 528
