Ga door naar hoofdinhoud
Oster 16-Speed Blender Blades Replacement
  1. Oster 16-Speed Blender Blades Replacement, Container: stap 1, afbeelding 1 van 2 Oster 16-Speed Blender Blades Replacement, Container: stap 1, afbeelding 2 van 2
    • First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
  2. Oster 16-Speed Blender Blades Replacement: stap 2, afbeelding 1 van 2 Oster 16-Speed Blender Blades Replacement: stap 2, afbeelding 2 van 2
    • Next, remove the lid from the Blender Container.
  3. Oster 16-Speed Blender Blades Replacement: stap 3, afbeelding 1 van 2 Oster 16-Speed Blender Blades Replacement: stap 3, afbeelding 2 van 2
    • Flip the container on its side so that the bottom faces you.
    • Now rotate the bottom counter-clockwise to remove it from the container.
  4. Oster 16-Speed Blender Blades Replacement: stap 4, afbeelding 1 van 2 Oster 16-Speed Blender Blades Replacement: stap 4, afbeelding 2 van 2
    • Now you will see the bottom of the blender blades once the bottom piece is removed
    • Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
  5. Oster 16-Speed Blender Blades Replacement: stap 5, afbeelding 1 van 1
    • Now your container is separated.
  6. Oster 16-Speed Blender Blades Replacement, Blades: stap 6, afbeelding 1 van 1
    • Flip the blender container on its side so that the bottom faces you.
    • Now, you can insert the new set of blades into the container.
    • Be careful when handling the blender blades as they are sharp and can cut you.
Conclusie
Dana
773 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-37, Maness Spring 2014 Lid van Cal Poly, Team 12-37, Maness Spring 2014
CPSU-MANESS-S14S12G37
4 Leden
7 handleidingen geschreven
Één opmerking
This is misleading, Step 1 shows a chrome ring on the bottom of the Blender Container, but all the other steps don’t show that.
This makes it very difficult to grip the black piece on the bottom of the Blender Container.
spbeggs - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 17
Altijd: 6,347
