Ga door naar hoofdinhoud
Osmo Mobile Bluetooth Module Replacement
Wat je nodig hebt
  1. Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: stap 1, afbeelding 1 van 2 Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: stap 1, afbeelding 2 van 2
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Bluetooth Module Replacement: stap 2, afbeelding 1 van 2 Osmo Mobile Bluetooth Module Replacement: stap 2, afbeelding 2 van 2
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Bluetooth Module Replacement: stap 3, afbeelding 1 van 1
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Bluetooth Module Replacement: stap 4, afbeelding 1 van 2 Osmo Mobile Bluetooth Module Replacement: stap 4, afbeelding 2 van 2
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Bluetooth Module Replacement: stap 5, afbeelding 1 van 3 Osmo Mobile Bluetooth Module Replacement: stap 5, afbeelding 2 van 3 Osmo Mobile Bluetooth Module Replacement: stap 5, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Bluetooth Module Replacement: stap 6, afbeelding 1 van 3 Osmo Mobile Bluetooth Module Replacement: stap 6, afbeelding 2 van 3 Osmo Mobile Bluetooth Module Replacement: stap 6, afbeelding 3 van 3
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
  7. Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: stap 7, afbeelding 1 van 3 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: stap 7, afbeelding 2 van 3 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: stap 7, afbeelding 3 van 3
    • Locate and remove the black screw found at the base of the grey mounting plate.
    • Remove the grey face plate.
  8. Osmo Mobile Bluetooth Module Replacement: stap 8, afbeelding 1 van 2 Osmo Mobile Bluetooth Module Replacement: stap 8, afbeelding 2 van 2
    Koop
    • Open the battery hatch and remove it by using the tweezers to press the hinge into the device.
    • Remove the black screw located underneath where the battery hatch was.
  9. Osmo Mobile Bluetooth Module Replacement: stap 9, afbeelding 1 van 2 Osmo Mobile Bluetooth Module Replacement: stap 9, afbeelding 2 van 2
    • Use the spudger to remove the front handle casing by sliding the spudger into the area between the handle grooves.
    • Slide the spudger around the groove to find the 6 clasps that hold the front part of the handle, and unclasp them.
    • Take off the front handle section to reveal the whole interior of the device.
  10. Osmo Mobile Bluetooth Module Replacement: stap 10, afbeelding 1 van 3 Osmo Mobile Bluetooth Module Replacement: stap 10, afbeelding 2 van 3 Osmo Mobile Bluetooth Module Replacement: stap 10, afbeelding 3 van 3
    • Locate and remove the black screw in the center of the motherboard chip.
    • Remove motherboard and replace.
Conclusie
William Tyler Wills
426 Reputatie
4 handleidingen geschreven
USF Tampa, Team S2-G1, Nance Fall 2017 Lid van USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 1,673
