Inleiding
This guide will assist you in removing the back casing of the clock to access the on/off switch and put it back in place.
Wat je nodig hebt
Hold clock so that the clock face is facing away from you.
Using your thumbs, push up on the battery cover.
Once battery cover is removed, pull down on AC Adapter Jack.
Use one hand to stabilize the clock.
Using your other hand, push batteries toward spring and pull out at an angle.
Use a Plastic Opening Tool to pry off the silver casing on the back.
Pry at the top of device.
Once the back is open at the top, pry at the side of the device closest to the battery compartment.
On/Off switch should come off with casing.
Insert switch into slot as shown in picture. Push in until you hear a "click."
Replace the back of the clock by pressing cover back into place.
3 andere personen hebben deze handleiding voltooid.
