Ga door naar hoofdinhoud
Oregon Scientific RM318PA Lens Replacement
Wat je nodig hebt
  1. Oregon Scientific RM318PA Lens Replacement, A/C Adapter: stap 1, afbeelding 1 van 3 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: stap 1, afbeelding 2 van 3 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: stap 1, afbeelding 3 van 3
    • Hold clock so the screen is facing away from you.
    • Using your thumbs, push up on battery cover to remove.
    • With your other hand, pull down on the A/C Adapter jack to remove.
  2. Oregon Scientific RM318PA Lens Replacement, Batteries: stap 2, afbeelding 1 van 1
    • Remove batteries by pushing a battery toward the spring.
    • Lift battery out at an angle. Repeat with second battery.
  3. Oregon Scientific RM318PA Lens Replacement, Projection Arm: stap 3, afbeelding 1 van 2 Oregon Scientific RM318PA Lens Replacement, Projection Arm: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
    • Once screws are removed, lift the back up and off of the projection arm.
  4. Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: stap 4, afbeelding 1 van 2 Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
  5. Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: stap 5, afbeelding 1 van 2 Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: stap 5, afbeelding 2 van 2
    • Use a Plastic Opening Tool to pry open the front of the projection arm casing. Start at the top of the projection arm.
    • Once top is partially open, use a Spudger to pry at the side of the projection arm.
  6. Oregon Scientific RM318PA Lens Replacement, Projection Beam: stap 6, afbeelding 1 van 3 Oregon Scientific RM318PA Lens Replacement, Projection Beam: stap 6, afbeelding 2 van 3 Oregon Scientific RM318PA Lens Replacement, Projection Beam: stap 6, afbeelding 3 van 3
    • Turn the clock on its side. Slide the focus wheel forward with your thumb.
    • The Projection Beam and Focus Wheel Component should now be free of Projection Arm.
    • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Wheel.
  7. Oregon Scientific RM318PA Lens Replacement, The Lens: stap 7, afbeelding 1 van 1
    • The Lens is attached to the Focus Knob and is now accessible for replacement purposes.
  8. Oregon Scientific RM318PA Lens Replacement, Tape: stap 8, afbeelding 1 van 1
    • Apply tape to the lens for safe removal and prevention of injury.
  9. Oregon Scientific RM318PA Lens Replacement, Focus Knob: stap 9, afbeelding 1 van 2 Oregon Scientific RM318PA Lens Replacement, Focus Knob: stap 9, afbeelding 2 van 2
    • Detach the focus knob from the internal casing of the lens by removing the screw from the base of the focus knob grip.
    • Pry apart the pieces of casing holding the focus knob in place and remove the knob.
  10. Oregon Scientific RM318PA Lens Replacement, Internal Casing: stap 10, afbeelding 1 van 3 Oregon Scientific RM318PA Lens Replacement, Internal Casing: stap 10, afbeelding 2 van 3 Oregon Scientific RM318PA Lens Replacement, Internal Casing: stap 10, afbeelding 3 van 3
    • Insert the spudger into the opening above the hinge on the side of the casing.
    • Press down firmly until the case opens.
  11. Oregon Scientific RM318PA Lens Replacement, Lens Removal: stap 11, afbeelding 1 van 2 Oregon Scientific RM318PA Lens Replacement, Lens Removal: stap 11, afbeelding 2 van 2
    • Pull apart the casing and gently slide lens from pocket.
    • Be sure to replace with a concave lens.
Conclusie
Één opmerking
Hi, I’ve this alarm clock with missing piezo/speaker, can anyone take a picture of the main board showing the pads for it?
Mastto geppetto - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 21
Altijd: 2,444
