Ga door naar hoofdinhoud
Oregon Scientific RM318PA Focus Knob Replacement
Wat je nodig hebt
  1. Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: stap 1, afbeelding 1 van 3 Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: stap 1, afbeelding 2 van 3 Oregon Scientific RM318PA Focus Knob Replacement, A/C Adapter: stap 1, afbeelding 3 van 3
    • Hold Clock so the screen is facing away from you.
    • Using your thumbs, push up on battery cover to remove.
    • With your other hand, pull down on the A/C Adapter jack to remove.
  2. Oregon Scientific RM318PA Focus Knob Replacement, Batteries: stap 2, afbeelding 1 van 1
    • Remove batteries by pushing a battery toward the spring.
    • Lift battery out at an angle. Repeat with second battery.
  3. Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: stap 3, afbeelding 1 van 3 Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: stap 3, afbeelding 2 van 3 Oregon Scientific RM318PA Focus Knob Replacement, Projection Arm: stap 3, afbeelding 3 van 3
    • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
    • Once screws are removed, lift the back up and off of the projection arm.
  4. Oregon Scientific RM318PA Focus Knob Replacement: stap 4, afbeelding 1 van 2 Oregon Scientific RM318PA Focus Knob Replacement: stap 4, afbeelding 2 van 2
    • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
  5. Oregon Scientific RM318PA Focus Knob Replacement: stap 5, afbeelding 1 van 2 Oregon Scientific RM318PA Focus Knob Replacement: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool to pry apart the front of the projection arm casing. Start at the top of the projection arm.
    • Once top is partially open, use a spudger to pry at the side of the projection arm.
  6. Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: stap 6, afbeelding 1 van 3 Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: stap 6, afbeelding 2 van 3 Oregon Scientific RM318PA Focus Knob Replacement, Focus Knob: stap 6, afbeelding 3 van 3
    • Turn the clock on its side. Slide the Focus Knob forward with your thumb.
    • The Focus Knob Component should now be free of Projection Arm.
    • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Knob.
  7. Oregon Scientific RM318PA Focus Knob Replacement: stap 7, afbeelding 1 van 3 Oregon Scientific RM318PA Focus Knob Replacement: stap 7, afbeelding 2 van 3 Oregon Scientific RM318PA Focus Knob Replacement: stap 7, afbeelding 3 van 3
    • Loosen Focus Knob by turning the Focus Knob counterclockwise with your fingers.
    • If needed, add a SMALL amount of WD-40 to the base of the knob and continue turning Focus Knob.
    • Place replacement Focus Knob in socket and turn clockwise to secure.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 829
