Inleiding
Use this guide to replace a damaged screen sensor in the Meep! X2 tablet.
Wat je nodig hebt
Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
Use a tweezer to gently pull the power button sensor out of the case's slot.
Use your tweezers to gently remove the microphone from the slot in the casing.
Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
Undo the security clips on the ribbon cable connection by placing the plastic opening tool between the black and white parts of the clip. Pull downard toward the gold ribbon cable.
Once the left and right clips are undone, remove the gold ribbon cable from that connection by gently pulling it out.
Remove the 10 phillips #00(3.5mm x 4mm) screws around the metal framing of the screen.
Leave the clear tape on the back of the screen until you are ready to remove it from the white plastic casing.
Use the spudger to undo the ribbon cable security clip located on the far left of the screen sensor.
