Ga door naar hoofdinhoud
Oregon Scientific Meep! X2 Cameras Replacement
Wat je nodig hebt
  1. Oregon Scientific Meep! X2 Cameras Replacement, Rear Casing: stap 1, afbeelding 1 van 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Cameras Replacement: stap 2, afbeelding 1 van 3 Oregon Scientific Meep! X2 Cameras Replacement: stap 2, afbeelding 2 van 3 Oregon Scientific Meep! X2 Cameras Replacement: stap 2, afbeelding 3 van 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Cameras Replacement: stap 3, afbeelding 1 van 3 Oregon Scientific Meep! X2 Cameras Replacement: stap 3, afbeelding 2 van 3 Oregon Scientific Meep! X2 Cameras Replacement: stap 3, afbeelding 3 van 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Cameras Replacement, Cameras: stap 4, afbeelding 1 van 2 Oregon Scientific Meep! X2 Cameras Replacement, Cameras: stap 4, afbeelding 2 van 2
    • Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
  5. Oregon Scientific Meep! X2 Cameras Replacement: stap 5, afbeelding 1 van 2 Oregon Scientific Meep! X2 Cameras Replacement: stap 5, afbeelding 2 van 2
    • Pry the second camera out of its slot with one of the plastic opening tools.
    • Be sure to undo the black adhesive foam from the metal casing in order to remove the camera properly.
  6. Oregon Scientific Meep! X2 Cameras Replacement: stap 6, afbeelding 1 van 1
    • Release the black security clip on the ribbon cable with your plastic opening tool.
    • Gently disconnect the gold ribbon cable from the motherboard. The two cameras will remain attached to the ribbon cable.
Conclusie
J'mel Henneman
864 Reputatie
8 handleidingen geschreven
USF Tampa, Team 9-1, Blackwell Winter 2015 Lid van USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 199
