Ga door naar hoofdinhoud
Ordro HDV-D395 Lens Replacement
Wat je nodig hebt
  1. Ordro HDV-D395 Lens Replacement, Lens: stap 1, afbeelding 1 van 2 Ordro HDV-D395 Lens Replacement, Lens: stap 1, afbeelding 2 van 2
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Lens Replacement: stap 2, afbeelding 1 van 1
    • Pull battery out of slot.
  3. Ordro HDV-D395 Lens Replacement: stap 3, afbeelding 1 van 1
    • Remove the three screws (length 7.7 mm) from the bottom of the outer case using a JIS000 screwdriver.
  4. Ordro HDV-D395 Lens Replacement: stap 4, afbeelding 1 van 2 Ordro HDV-D395 Lens Replacement: stap 4, afbeelding 2 van 2
    • Remove plastic casing hiding screws from the strap side of the casing.
    • Unscrew the three screws (length 4.75 mm) using a PH000 screwdriver.
    • Unscrew the two screws (length 6.4 mm) using a JIS000 screwdriver.
  5. Ordro HDV-D395 Lens Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the four screws (2.9 mm length) from the screen side of the casing using a JIS000 screwdriver.
  6. Ordro HDV-D395 Lens Replacement: stap 6, afbeelding 1 van 1
    • Remove both side casings by gripping the sides with your hands and pulling gently.
  7. Ordro HDV-D395 Lens Replacement: stap 7, afbeelding 1 van 3 Ordro HDV-D395 Lens Replacement: stap 7, afbeelding 2 van 3 Ordro HDV-D395 Lens Replacement: stap 7, afbeelding 3 van 3
    • Although it requires extra steps, it is advised that you remove the motherboard and screen to ensure that nothing is damaged in the process of replacing the lens.
    • Unscrew the seven screws (length 4.22 mm) from the motherboard using a PH000 screwdriver.
    • Pull out or desolder all connected cords from motherboard.
  8. Ordro HDV-D395 Lens Replacement: stap 8, afbeelding 1 van 2 Ordro HDV-D395 Lens Replacement: stap 8, afbeelding 2 van 2
    • Remove top of the casing to reveal the screws on lens.
    • Unscrew the four screws (size 4.90 mm) using a PH00 screwdriver.
  9. Ordro HDV-D395 Lens Replacement: stap 9, afbeelding 1 van 3 Ordro HDV-D395 Lens Replacement: stap 9, afbeelding 2 van 3 Ordro HDV-D395 Lens Replacement: stap 9, afbeelding 3 van 3
    • Pull out lens.
    • Remove cord from lens.
Conclusie
Nathan Mcintyre
303 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G3, Baechle Fall 2018 Lid van IUPUI, Team S1-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G3
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 224
