Ga door naar hoofdinhoud
Ordro HDV-D395 Back Case Replacement
Wat je nodig hebt
  1. Ordro HDV-D395 Back Case Replacement, Back Case: stap 1, afbeelding 1 van 2 Ordro HDV-D395 Back Case Replacement, Back Case: stap 1, afbeelding 2 van 2
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Back Case Replacement: stap 2, afbeelding 1 van 1
    • Pull battery out of slot.
  3. Ordro HDV-D395 Back Case Replacement: stap 3, afbeelding 1 van 1
    • Unfold the screen from the side of the camera.
  4. Ordro HDV-D395 Back Case Replacement: stap 4, afbeelding 1 van 1
    • Twist the screen so that the screen is facing downward.
  5. Ordro HDV-D395 Back Case Replacement: stap 5, afbeelding 1 van 2 Ordro HDV-D395 Back Case Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the four screws on the side (length 2.9 mm) with a JIS #000 screwdriver.
    • Unscrew the three screws on the bottom (length 7.7 mm) with a JIS #000 screwdriver.
  6. Ordro HDV-D395 Back Case Replacement: stap 6, afbeelding 1 van 1
    • Pull apart the camera into two pieces by pulling the side with the screen away from the main body of the camera.
  7. Ordro HDV-D395 Back Case Replacement: stap 7, afbeelding 1 van 2 Ordro HDV-D395 Back Case Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the two screws (size 4.75 mm) with a PH #00 screwdriver.
    • Unscrew the screw (size 7.65 mm) with a PH #00 screwdriver.
  8. Ordro HDV-D395 Back Case Replacement: stap 8, afbeelding 1 van 1
    • Take the back case off by pulling it away from the main body.
    • Be careful not to tear the white strap that connects the back case to the main body.
  9. Ordro HDV-D395 Back Case Replacement: stap 9, afbeelding 1 van 1
    • Unscrew all four screws (length 4.13 mm) on the inside of the case with a PH #00 screwdriver.
  10. Ordro HDV-D395 Back Case Replacement: stap 10, afbeelding 1 van 1
    • Pull the board away from the back case.
Conclusie
Mostafa Abdulaleem
181 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G3, Baechle Fall 2018 Lid van IUPUI, Team S1-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G3
3 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 295
