Wat je nodig hebt
Gereedschap gebruikt in deze stap:Tweezers$3.99
Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
Gereedschap gebruikt in deze stap:Anti-Static Wrist Strap$7.95
Remove the anti-static wrist strap.
Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
Use a pair of angled tweezers to remove the speaker housing.
