Inleiding
This guide covers the steps to remove and replace the broken screen on your Orbic wonder. Some steps are repeated, as this is a guide made up of other guides.
Wat je nodig hebt
Remove the anti-static wrist strap.
Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
Detach the metal casing at the bottom of the phone.
Unplug the cable connector.
Use a pair of angled tweezers to unplug the black wire.
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
how can and or can I swap media files from orbic wonder “with damaged screen “ to a gaxalxy a01
