Ga door naar hoofdinhoud
Orbic Wonder Battery Replacement
Wat je nodig hebt
  1. Orbic Wonder Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Orbic Wonder Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Orbic Wonder Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
  2. Orbic Wonder Battery Replacement: stap 2, afbeelding 1 van 3 Orbic Wonder Battery Replacement: stap 2, afbeelding 2 van 3 Orbic Wonder Battery Replacement: stap 2, afbeelding 3 van 3
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
  3. Orbic Wonder Battery Replacement: stap 3, afbeelding 1 van 3 Orbic Wonder Battery Replacement: stap 3, afbeelding 2 van 3 Orbic Wonder Battery Replacement: stap 3, afbeelding 3 van 3
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an ā€œLā€. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
  4. Orbic Wonder Battery Replacement: stap 4, afbeelding 1 van 3 Orbic Wonder Battery Replacement: stap 4, afbeelding 2 van 3 Orbic Wonder Battery Replacement: stap 4, afbeelding 3 van 3
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
  5. Orbic Wonder Battery Replacement: stap 5, afbeelding 1 van 3 Orbic Wonder Battery Replacement: stap 5, afbeelding 2 van 3 Orbic Wonder Battery Replacement: stap 5, afbeelding 3 van 3
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
Conclusie
3 opmerkingen
where do you buy the replacement battery at ?
ricotoomo - Antwoord
Where can I buy a replacement battery
Robert Smith -
Thank you big help your smart
gansterms123 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 79
Altijd: 6,584
