Ga door naar hoofdinhoud
Oral-B Vitality Power Button Replacement
Wat je nodig hebt
  1. Oral-B Vitality Power Button Replacement, Power Button: stap 1, afbeelding 1 van 3 Oral-B Vitality Power Button Replacement, Power Button: stap 1, afbeelding 2 van 3 Oral-B Vitality Power Button Replacement, Power Button: stap 1, afbeelding 3 van 3
    • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
  2. Oral-B Vitality Power Button Replacement: stap 2, afbeelding 1 van 1
    • Locate the 4 terminals connecting the power button to the circuit board.
  3. Oral-B Vitality Power Button Replacement: stap 3, afbeelding 1 van 3 Oral-B Vitality Power Button Replacement: stap 3, afbeelding 2 van 3 Oral-B Vitality Power Button Replacement: stap 3, afbeelding 3 van 3
    • Desolder the 4 terminals and remove the old button.
    • Remove as much of the old solder as possible.
  4. Oral-B Vitality Power Button Replacement: stap 4, afbeelding 1 van 1
    • Attach the new button by soldering the 4 terminals with new solder.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Grady Bennett
503 Reputatie
2 handleidingen geschreven
IUPUI, Team S2-G1, Harley Fall 2017 Lid van IUPUI, Team S2-G1, Harley Fall 2017
IUPUI-HARLEY-F17S2G1
3 Leden
8 handleidingen geschreven
4 opmerkingen
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - Antwoord
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - Antwoord
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - Antwoord
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 212
Altijd: 9,776
