Ga door naar hoofdinhoud
Oral-B Black 7000 Battery Replacement
Wat je nodig hebt
  1. Oral-B Black 7000 Battery Replacement, Induction Charging Coil: stap 1, afbeelding 1 van 3 Oral-B Black 7000 Battery Replacement, Induction Charging Coil: stap 1, afbeelding 2 van 3 Oral-B Black 7000 Battery Replacement, Induction Charging Coil: stap 1, afbeelding 3 van 3
    • Use the charging station to remove the a small plastic plug from the end of the toothbrush by inserting the charging station into the end insert and twisting counter-clockwise by 90 degrees.
  2. Oral-B Black 7000 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the end cap from the bottom of the toothbrush by prying it off with a spudger.
  3. Oral-B Black 7000 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the top cap by using a spudger to pry the plastic ring off of the toothbrush frame.
  4. Oral-B Black 7000 Battery Replacement: stap 4, afbeelding 1 van 2 Oral-B Black 7000 Battery Replacement: stap 4, afbeelding 2 van 2
    • Use a spudger to loosen the two plastic tabs next to the induction coil that secure the internal assembly to the frame.
    • Push on the rotating head in order to pop the assembly out of the black plastic casing.
    • You can also use a spudger to leverage the assembly out, but this may break the copper wire connected to the induction coil, so be careful.
  5. Oral-B Black 7000 Battery Replacement: stap 5, afbeelding 1 van 1
    • Unwrap the ends of the wires from the white plastic pegs using a pair of tweezers.
    • Each wire end is wrapped around the peg 3-4 times.
  6. Oral-B Black 7000 Battery Replacement: stap 6, afbeelding 1 van 1
    • Melt the solder at the two pads on either side of the top of the motherboard. This will require a high heat soldering iron. Remove the wire from the solder pads using tweezers once the solder melts.
  7. Oral-B Black 7000 Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the induction coil by pulling the plastic tabs out of their keepers.
    • A spudger can be used to remove the plastic tabs from their keepers if neccessary.
  8. Oral-B Black 7000 Battery Replacement, Battery: stap 8, afbeelding 1 van 1
    • Remove the spring from the housing using a nylon spudger.
  9. Oral-B Black 7000 Battery Replacement: stap 9, afbeelding 1 van 2 Oral-B Black 7000 Battery Replacement: stap 9, afbeelding 2 van 2
    • Use a soldering iron to melt the solder pad at the top of the motherboard, which attaches a battery electrode to the board. Remove the electrode by pulling it through the plastic housing after it has been desoldered from the board.
    • Repeat with the two solder pads on either side of the motherboard just above the black diamond-shaped component. The electrode foils can be pulled through the board from the back after the solder is melted.
  10. Oral-B Black 7000 Battery Replacement: stap 10, afbeelding 1 van 1
    • Use a metal spudger to pop the battery out of its casing. The electrodes will remain attached to the battery.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Jonathan Bowyer
387 Reputatie
3 handleidingen geschreven
IUPUI, Team S1-G1, Harley Fall 2017 Lid van IUPUI, Team S1-G1, Harley Fall 2017
IUPUI-HARLEY-F17S1G1
3 Leden
14 handleidingen geschreven
4 opmerkingen
Wo bekommt man einen neuen AKU
Andreas
Andreas Kappos - Antwoord
Der sollte es sein. Er muss Lötfahnen haben! Miss die Länge nach, 42 oder 48 mm.
https://www.amazon.de/Ersatzakku-mit-Ein...
VauWeh -
What size battery do you need to replace this one?
pat-gray - Antwoord
Please check your device to be sure, but for me, it needed a battery of 48mm in length and 17mm in diameter. On top of that, it needs to have solder pads to make sure you can attach it properly.
Thijs -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 95
Afgelopen 30 dagen: 456
Altijd: 28,707
