Inleiding
The optical drive allows your laptop to read optical discs.
If your laptop cannot read discs anymore but other devices can read the same discs, your optical drive may be faulty and should be replaced.
Wat je nodig hebt
Now that the backing plate is off make sure to be careful of the Motherboard and its components from being damaged. From here on out it is recommended that you wear an anti static bracelet or at the very least touching something metal to remove any static electricity that you may have built up.
