Ga door naar hoofdinhoud
Oppo X9000 Speaker Drivers Replacement
Wat je nodig hebt
  1. Oppo X9000 Speaker Drivers Replacement, Removing the Back Cover: stap 1, afbeelding 1 van 2 Oppo X9000 Speaker Drivers Replacement, Removing the Back Cover: stap 1, afbeelding 2 van 2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
  2. Oppo X9000 Speaker Drivers Replacement, Removing the Battery: stap 2, afbeelding 1 van 1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
  3. Oppo X9000 Speaker Drivers Replacement, Remove the Back Panel Screws: stap 3, afbeelding 1 van 2 Oppo X9000 Speaker Drivers Replacement, Remove the Back Panel Screws: stap 3, afbeelding 2 van 2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
  4. Oppo X9000 Speaker Drivers Replacement, Remove the Rubber Stoppers: stap 4, afbeelding 1 van 2 Oppo X9000 Speaker Drivers Replacement, Remove the Rubber Stoppers: stap 4, afbeelding 2 van 2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
  5. Oppo X9000 Speaker Drivers Replacement, Remove the Newly Exposed Screws: stap 5, afbeelding 1 van 1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
  6. Oppo X9000 Speaker Drivers Replacement, Lift off the Back Panel: stap 6, afbeelding 1 van 2 Oppo X9000 Speaker Drivers Replacement, Lift off the Back Panel: stap 6, afbeelding 2 van 2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
  7. Oppo X9000 Speaker Drivers Replacement, Remove the Speaker Drivers: stap 7, afbeelding 1 van 2 Oppo X9000 Speaker Drivers Replacement, Remove the Speaker Drivers: stap 7, afbeelding 2 van 2
    • Using the flat end of the spudger, pry the speaker drivers off of the chassis.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sara Dafoe
354 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-45, Amido Fall 2014 Lid van Cal Poly, Team 4-45, Amido Fall 2014
CPSU-AMIDO-F14S4G45
5 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 861
