Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
Without removing any electrical connections, open the left side of the column as wide as practical.
Make sure no electrical connections are touching the column.
Make sure all green/brown grounding (earthing) cables are securely in place.
