Ga door naar hoofdinhoud
Inleiding
Utilize this guide to access inside the column, a step required for other guides such as replacing the power supply. For more information on opening the column, please refer to page 11-6 in the full service manual.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
  1. Use a grounding cable and wrist band connected to the GALILEO or other work surface  when you are working on the GALILEO.
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Without removing any electrical connections, open the left side of the column as wide as practical. This exposes:  GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
Conclusie
Ian Van Sciver
303 Reputatie
2 handleidingen geschreven
Cal Poly, Team S7-G26, Paton Spring 2020 Lid van Cal Poly, Team S7-G26, Paton Spring 2020
CPSU-PATON-S20S7G26
3 Leden
4 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 53
