Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
How to open your Link.usb Audio Interface device despite no visible screws.
Onderdelen
Geen onderdelen opgegeven.
  1. Put the device in front of you, with the knob labels the right side up
    • Put the device in front of you, with the knob labels the right side up
  2. Pry the rubber off the top of the device All the rubber
    • Pry the rubber off the top of the device
    • All the rubber
    • Use your fingernails, then pull with your bare hands. Do no use a heat gun or prying tool as they will damage the adhesive.
    • 5 screw holes will appear. Leave them alone for now.
  3. OPEN ALLE TABBLADEN
    RAM-upgradekits voor Mac
    Koop kits
    Genoeg RAM
    voor al je tabbladen
    Koop kits
  4. Look at the side of the device with the metal stand Take a heat gun to the two small foam pads
    • Look at the side of the device with the metal stand
    • Take a heat gun to the two small foam pads
    • You only need to pry off the halves on the top plastic shell
    • Put scraps of glossy paper on the foam pads to prevent them from sticking on again
    • Alternatively, if you do not mind sacrificing aesthetics, you may slice the foam pads down the middle as in the picture.
  5. Now remove the 5 Philips screws on top Now remove the 5 Philips screws on top
    • Now remove the 5 Philips screws on top
  6. Simply lift off the top
    • Simply lift off the top
    • No clips anywhere
  7. You could now lift out the whole innards
    • You could now lift out the whole innards
    • They are not attached to the bottom shell
    • No, the mess of glue is how it left the factory
Conclusie
Tobias
10 Reputatie
2 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 178
