Wat je nodig hebt
Take sim tray out prior to beginning repair.
Heat back of phone to make the adhesion more pliable
Insert a slim prying tool to begin removing the back cover, move in a counterclockwise direction
Add IPA as you work to detatch the adhesion layer
When approaching the volume button, be cautious, as the ribbon cable is exposed and can easilyt be cut
Remove back cover
Bijna klaar!
This order can be used for charger, headphone jack, or water damage to sub board.
Conclusie
