Ga door naar hoofdinhoud
OnePlus 6T Speaker Replacement
Wat je nodig hebt
  1. OnePlus 6T Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Speaker Replacement: stap 2, afbeelding 1 van 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Speaker Replacement: stap 3, afbeelding 1 van 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Speaker Replacement: stap 4, afbeelding 1 van 3 OnePlus 6T Speaker Replacement: stap 4, afbeelding 2 van 3 OnePlus 6T Speaker Replacement: stap 4, afbeelding 3 van 3
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Speaker Replacement, Speaker: stap 5, afbeelding 1 van 1
    • Remove seven 3mm Phillips #00 screws from the speaker.
  6. OnePlus 6T Speaker Replacement: stap 6, afbeelding 1 van 1
    • Use a spudger to lift and remove the speaker.
Conclusie
7 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 41
Altijd: 3,223
