Ga door naar hoofdinhoud
OnePlus 6T Rear Camera Replacement
Wat je nodig hebt
  1. OnePlus 6T Rear Camera Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Rear Camera Replacement: stap 3, afbeelding 1 van 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Rear Camera Replacement: stap 4, afbeelding 1 van 3 OnePlus 6T Rear Camera Replacement: stap 4, afbeelding 2 van 3 OnePlus 6T Rear Camera Replacement: stap 4, afbeelding 3 van 3
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Rear Camera Replacement, Front Camera: stap 5, afbeelding 1 van 2 OnePlus 6T Rear Camera Replacement, Front Camera: stap 5, afbeelding 2 van 2
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
  6. OnePlus 6T Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
  7. OnePlus 6T Rear Camera Replacement: stap 7, afbeelding 1 van 1
    • Using a spudger, gently remove the midframe and place it to the side.
  8. OnePlus 6T Rear Camera Replacement: stap 8, afbeelding 1 van 1
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
  9. OnePlus 6T Rear Camera Replacement, Motherboard: stap 9, afbeelding 1 van 2 OnePlus 6T Rear Camera Replacement, Motherboard: stap 9, afbeelding 2 van 2
    • Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
  10. OnePlus 6T Rear Camera Replacement: stap 10, afbeelding 1 van 1
    • Using a spudger, disconnect the charging port flex connector, the main flex connector, and the screen flex connector at the bottom of the camera.
  11. OnePlus 6T Rear Camera Replacement: stap 11, afbeelding 1 van 1
    • Use a spudger to disconnect the signal cables on the right side of the motherboard.
  12. OnePlus 6T Rear Camera Replacement: stap 12, afbeelding 1 van 2 OnePlus 6T Rear Camera Replacement: stap 12, afbeelding 2 van 2
    • Disconnect the slider from the top of the phone with a spudger.
    • The slider is extremely delicate, so it is important you do not attempt to remove it from the sides.
    • Gently pull the motherboard from the left side and remove it from the phone.
  13. OnePlus 6T Rear Camera Replacement, Rear Camera: stap 13, afbeelding 1 van 2 OnePlus 6T Rear Camera Replacement, Rear Camera: stap 13, afbeelding 2 van 2
    • Using a spudger, disconnect the two metal rear camera tabs on the left side of the camera.
    • Remove the camera from its slot on the motherboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
In step 6 the screw under the humidity sensor is not shown. this needs to be removed as well
W W - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 1,049
