Ga door naar hoofdinhoud
OnePlus 6T Front Camera Replacement
Wat je nodig hebt
  1. OnePlus 6T Front Camera Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
  2. OnePlus 6T Front Camera Replacement: stap 2, afbeelding 1 van 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
  3. OnePlus 6T Front Camera Replacement: stap 3, afbeelding 1 van 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
  4. OnePlus 6T Front Camera Replacement: stap 4, afbeelding 1 van 3 OnePlus 6T Front Camera Replacement: stap 4, afbeelding 2 van 3 OnePlus 6T Front Camera Replacement: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
  5. OnePlus 6T Front Camera Replacement, Front Camera: stap 5, afbeelding 1 van 2 OnePlus 6T Front Camera Replacement, Front Camera: stap 5, afbeelding 2 van 2
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
  6. OnePlus 6T Front Camera Replacement: stap 6, afbeelding 1 van 1
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
  7. OnePlus 6T Front Camera Replacement: stap 7, afbeelding 1 van 1
    • Using a spudger, gently remove the midframe and place it to the side.
  8. OnePlus 6T Front Camera Replacement: stap 8, afbeelding 1 van 1
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
Conclusie
Kristen Gismondi
82.095 Reputatie
200 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.218 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 29
Altijd: 1,109
