Ga door naar hoofdinhoud
OnePlus 6 Motherboard Replacement
Wat je nodig hebt
  1. OnePlus 6 Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Motherboard Replacement: stap 2, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Motherboard Replacement: stap 3, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Motherboard Replacement, Battery: stap 4, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement, Battery: stap 4, afbeelding 2 van 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
  5. OnePlus 6 Motherboard Replacement, Midframe: stap 5, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement, Midframe: stap 5, afbeelding 2 van 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the screw at the bottom left is marked wrong in this picture. The actual 10th screw is actually underneath the round white sticker. Do not remove the screw marked at bottom left, but strip over the white sticker which has a screw underneath it. Otherwise you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
  6. OnePlus 6 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
  7. OnePlus 6 Motherboard Replacement: stap 7, afbeelding 1 van 2 OnePlus 6 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
    • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
    • The cameras should lift up with the motherboard.
Conclusie
4 andere personen hebben deze handleiding voltooid.
John Steven Trammell
789 Reputatie
4 handleidingen geschreven
Clemson, Team 4-3, Hunter Fall 2021 Lid van Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Leden
14 handleidingen geschreven
Één opmerking
Can you repair my One plus 6. It's one IC of motherboard is damaged.
AMIT PANWAR - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 103
Altijd: 3,200
