Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
OnePlus 5 Back Cover Replacement
Wat je nodig hebt
  1. OnePlus 5 Back Cover Replacement, SIM Card Tray: stap 1, afbeelding 1 van 3 OnePlus 5 Back Cover Replacement, SIM Card Tray: stap 1, afbeelding 2 van 3 OnePlus 5 Back Cover Replacement, SIM Card Tray: stap 1, afbeelding 3 van 3
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
    • Press firmly to eject the tray.
    • During reassembly, be sure to properly orient the SIM tray you you insert it.
  2. OnePlus 5 Back Cover Replacement, Back Cover: stap 2, afbeelding 1 van 1
    • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
  3. OnePlus 5 Back Cover Replacement: stap 3, afbeelding 1 van 3 OnePlus 5 Back Cover Replacement: stap 3, afbeelding 2 van 3 OnePlus 5 Back Cover Replacement: stap 3, afbeelding 3 van 3
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the body and the screen of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
    • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
  4. OnePlus 5 Back Cover Replacement: stap 4, afbeelding 1 van 2 OnePlus 5 Back Cover Replacement: stap 4, afbeelding 2 van 2
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
  5. OnePlus 5 Back Cover Replacement: stap 5, afbeelding 1 van 3 OnePlus 5 Back Cover Replacement: stap 5, afbeelding 2 van 3 OnePlus 5 Back Cover Replacement: stap 5, afbeelding 3 van 3
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
  6. OnePlus 5 Back Cover Replacement: stap 6, afbeelding 1 van 2 OnePlus 5 Back Cover Replacement: stap 6, afbeelding 2 van 2
    • Lever the opening tool to release the first clip from the frame.
  7. OnePlus 5 Back Cover Replacement: stap 7, afbeelding 1 van 3 OnePlus 5 Back Cover Replacement: stap 7, afbeelding 2 van 3 OnePlus 5 Back Cover Replacement: stap 7, afbeelding 3 van 3
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
  8. OnePlus 5 Back Cover Replacement: stap 8, afbeelding 1 van 1
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
  9. OnePlus 5 Back Cover Replacement: stap 9, afbeelding 1 van 3 OnePlus 5 Back Cover Replacement: stap 9, afbeelding 2 van 3 OnePlus 5 Back Cover Replacement: stap 9, afbeelding 3 van 3
    • With all the clips released, flip the phone over so that the display is face-down.
    • Swing the back cover around and rest it on top of the exposed frame.
    • Be careful not to stress the flex cable connecting the back cover and the frame.
  10. OnePlus 5 Back Cover Replacement: stap 10, afbeelding 1 van 2 OnePlus 5 Back Cover Replacement: stap 10, afbeelding 2 van 2
    • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
    • Lift up and remove the cable bracket.
    • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
  11. OnePlus 5 Back Cover Replacement: stap 11, afbeelding 1 van 2 OnePlus 5 Back Cover Replacement: stap 11, afbeelding 2 van 2
    • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  12. OnePlus 5 Back Cover Replacement: stap 12, afbeelding 1 van 1
    • Remove the back cover.
Conclusie
Repair didn’t go as planned? Check out our OnePlus 5 Answers community for troubleshooting help.
10 andere personen hebben deze handleiding voltooid.
Arthur Shi
249.670 Reputatie
503 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.718 handleidingen geschreven
Één opmerking
This is a useless guide, I need help with replacing the backcover entirely to a new backcover, I need to remove and attach components from the old backcover to the new one.
Niko - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 42
Altijd: 5,131
