Inleiding
The battery is the backup to the device's hardwired design and is meant to last ten years. However, if the battery fails, follow this guide to replace the battery of your OneLink Safe and Sound. It's important to have the battery installed and working in case of a power outage and the hardwire is inoperable.
Wat je nodig hebt
Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
Remove plastic rim.
Één andere persoon heeft deze handleiding voltooid.
4 opmerkingen
Where do I get this battery replacement
people that has purchased this product. If the battery goes dead where can someone purchase a replacement battery from and what size battery would they need
Is there a P/N for the battery pack or it needs to be bought individually and then put together
Thank you
Bought a 2CR17335A-WK17 battery pack from Amazon for $15 plus tax. Just had to splice wires to existing connector to match the motherboard. So far so good. Had a 5 chirp tone every 2 minutes advising battery had come to end of life. Not sure why a 10 year battery only lasted 3 years from the manufacturing date but oh well.
