Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use a spudger to disconnect the black bundled cable connector from the motherboard.
Use a spudger to lift the black tab on top of the ZIF connector.
Slide the ribbon cable out of the connector.
Use a spudger to flip up the black retaining flap on the ZIF connector.
Pull the folded ribbon cable straight out of the connector.
Use a spudger to pry the battery away from the device.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Use ESD safe tweezers to disconnect the antenna from the motherboard.
Use a spudger to flip up the black flap on the camera's ZIF connector.
Pull the ribbon cable straight out of the connector.
Use tweezers to pull the dock connection cable away from the motherboard.
Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
Lift the protective shield away from the motherboard.
With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
Gently lift the motherboard away from the display assembly.
Één andere persoon heeft deze handleiding voltooid.
