Ga door naar hoofdinhoud
One Education Infinity:One Motherboard Replacement
Wat je nodig hebt
  1. One Education Infinity:One Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 One Education Infinity:One Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Motherboard Replacement: stap 2, afbeelding 1 van 3 One Education Infinity:One Motherboard Replacement: stap 2, afbeelding 2 van 3 One Education Infinity:One Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Motherboard Replacement: stap 3, afbeelding 1 van 3 One Education Infinity:One Motherboard Replacement: stap 3, afbeelding 2 van 3 One Education Infinity:One Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Motherboard Replacement, Antenna: stap 5, afbeelding 1 van 2 One Education Infinity:One Motherboard Replacement, Antenna: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
  6. One Education Infinity:One Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 One Education Infinity:One Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 One Education Infinity:One Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Use tweezers to pull the dock connection cable away from the motherboard.
  8. One Education Infinity:One Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
    • Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
  9. One Education Infinity:One Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Lift the protective shield away from the motherboard.
  10. One Education Infinity:One Motherboard Replacement: stap 10, afbeelding 1 van 3 One Education Infinity:One Motherboard Replacement: stap 10, afbeelding 2 van 3 One Education Infinity:One Motherboard Replacement: stap 10, afbeelding 3 van 3
    • With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
    • Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
    • During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
  11. One Education Infinity:One Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Gently lift the motherboard away from the display assembly.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Taylor Bratsch
6.095 Reputatie
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 625
