Inleiding
This guide can be used to remove the entire hinge or the hinge contact assembly. The hinge, along with its contact assembly, connects the keyboard base with the tablet. If the tablet fails to recognize the keyboard, replacing this contact assembly might solve the problem.
Wat je nodig hebt
Use a spudger to pry the four rubber pads away from the bottom of the case.
Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
Één opmerking
Everything is very detailed and shown. Everything is also done in detail on this site ++https://oceanessay.com/buy-thesis-pape... , which helps students learn. There you will find a lot of educational materials.
