Ga door naar hoofdinhoud
One Education Infinity One Touchpad Replacement
Wat je nodig hebt
  1. One Education Infinity One Touchpad Replacement, Back Case: stap 1, afbeelding 1 van 2 One Education Infinity One Touchpad Replacement, Back Case: stap 1, afbeelding 2 van 2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity One Touchpad Replacement: stap 2, afbeelding 1 van 2 One Education Infinity One Touchpad Replacement: stap 2, afbeelding 2 van 2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity One Touchpad Replacement: stap 3, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity One Touchpad Replacement: stap 4, afbeelding 1 van 2 One Education Infinity One Touchpad Replacement: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity One Touchpad Replacement, Daughterboard: stap 5, afbeelding 1 van 2 One Education Infinity One Touchpad Replacement, Daughterboard: stap 5, afbeelding 2 van 2
    • Flip up the black retaining flap on the ZIF connector holding the large grey ribbon cable in place.
    • Pull the ribbon cable straight out of the ZIF connector.
  6. One Education Infinity One Touchpad Replacement: stap 6, afbeelding 1 van 2 One Education Infinity One Touchpad Replacement: stap 6, afbeelding 2 van 2
    • Use the flat end of a spudger to flip up the black tab on the smaller ZIF connector.
    • Use tweezers to pull the ribbon cable straight out of the connector.
  7. One Education Infinity One Touchpad Replacement: stap 7, afbeelding 1 van 3 One Education Infinity One Touchpad Replacement: stap 7, afbeelding 2 van 3 One Education Infinity One Touchpad Replacement: stap 7, afbeelding 3 van 3
    • Use a Phillips #000 screwdriver to unscrew the three 3.4mm screws.
    • Lift the daughterboard away from the device to remove.
  8. One Education Infinity One Touchpad Replacement, Keyboard Frame Prerequisite: stap 8, afbeelding 1 van 2 One Education Infinity One Touchpad Replacement, Keyboard Frame Prerequisite: stap 8, afbeelding 2 van 2
    • Use a spudger to lift up the black retaining flap on the touchpad's ZIF connector.
    • Pull the ribbon cable straight back to remove.
  9. One Education Infinity One Touchpad Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws holding the touchpad in place.
  10. One Education Infinity One Touchpad Replacement: stap 10, afbeelding 1 van 2 One Education Infinity One Touchpad Replacement: stap 10, afbeelding 2 van 2
    • Feed the ribbon cable through the hole in the metal frame.
    • Left the metal frame away from the device.
  11. One Education Infinity One Touchpad Replacement, Touchpad: stap 11, afbeelding 1 van 2 One Education Infinity One Touchpad Replacement, Touchpad: stap 11, afbeelding 2 van 2
    • Use a spudger to pry the touchpad away from the device.
Conclusie
Taylor Bratsch
6.095 Reputatie
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 330
