Ga door naar hoofdinhoud
One Education Infinity Heatsink Replacement
Wat je nodig hebt
  1. One Education Infinity Heatsink Replacement, Back Case: stap 1, afbeelding 1 van 3 One Education Infinity Heatsink Replacement, Back Case: stap 1, afbeelding 2 van 3 One Education Infinity Heatsink Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Heatsink Replacement: stap 2, afbeelding 1 van 2 One Education Infinity Heatsink Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Heatsink Replacement: stap 3, afbeelding 1 van 3 One Education Infinity Heatsink Replacement: stap 3, afbeelding 2 van 3 One Education Infinity Heatsink Replacement: stap 3, afbeelding 3 van 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Heatsink Replacement, Battery: stap 4, afbeelding 1 van 3 One Education Infinity Heatsink Replacement, Battery: stap 4, afbeelding 2 van 3 One Education Infinity Heatsink Replacement, Battery: stap 4, afbeelding 3 van 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Heatsink Replacement: stap 5, afbeelding 1 van 3 One Education Infinity Heatsink Replacement: stap 5, afbeelding 2 van 3 One Education Infinity Heatsink Replacement: stap 5, afbeelding 3 van 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Heatsink Replacement, Heatsink: stap 6, afbeelding 1 van 2 One Education Infinity Heatsink Replacement, Heatsink: stap 6, afbeelding 2 van 2
    • Remove the eight 2.8 mm screws from the heatsink with a Phillips #00 screwdriver.
  7. One Education Infinity Heatsink Replacement: stap 7, afbeelding 1 van 3 One Education Infinity Heatsink Replacement: stap 7, afbeelding 2 van 3 One Education Infinity Heatsink Replacement: stap 7, afbeelding 3 van 3
    • Insert the tip of a spudger into the small gap along the right side edge of the heatsink and pry upward to free it from the clips.
  8. One Education Infinity Heatsink Replacement: stap 8, afbeelding 1 van 1
    • Lift the heatsink up from the motherboard.
Conclusie
Austin Blakely
19.649 Reputatie
53 handleidingen geschreven
iFixit Lid van iFixit
Staff
136 Leden
17.430 handleidingen geschreven
Één opmerking
Thanks for sharing. I will comeback here soon!
mabel goodrich - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 197
