Ga door naar hoofdinhoud
Onda V701 Speaker Replacement
Wat je nodig hebt
  1. Onda V701 Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 3 Onda V701 Speaker Replacement, Back Panel: stap 1, afbeelding 2 van 3 Onda V701 Speaker Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Speaker Replacement: stap 2, afbeelding 1 van 3 Onda V701 Speaker Replacement: stap 2, afbeelding 2 van 3 Onda V701 Speaker Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Speaker Replacement: stap 3, afbeelding 1 van 2 Onda V701 Speaker Replacement: stap 3, afbeelding 2 van 2
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Speaker Replacement: stap 4, afbeelding 1 van 2 Onda V701 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Speaker Replacement: stap 5, afbeelding 1 van 3 Onda V701 Speaker Replacement: stap 5, afbeelding 2 van 3 Onda V701 Speaker Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Onda V701 Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    • Desolder the black(-) and red(+) wires connecting the speaker to the motherboard using a soldering iron and tweezers to hold the wire.
    • Soldering requires a lot of heat. Do not touch the metal part of the soldering iron. Wear gloves if necessary to protect your hands. The fumes from soldering could also be toxic. Work in a well ventilated area and/or use a respirator.
  7. Onda V701 Speaker Replacement: stap 7, afbeelding 1 van 3 Onda V701 Speaker Replacement: stap 7, afbeelding 2 van 3 Onda V701 Speaker Replacement: stap 7, afbeelding 3 van 3
    • Carefully pry the speaker assembly off of the back panel using a spudger.
    • The speaker is held on with a small amount of adhesive.
Conclusie
Bradley Huber
366 Reputatie
3 handleidingen geschreven
Colorado Springs, Team 4-6, Panko Spring 2015 Lid van Colorado Springs, Team 4-6, Panko Spring 2015
UCCS-PANKO-S15S4G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 215
