Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the four 4.8mm mounting screws using a PH00 screwdriver.
Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
Gently lift the screen assembly away from the back cover assembly.
Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
Remove the ribbon cables.
Gently pry the front-facing camera away from the back panel using a spudger.
Flip the gray locking tab of the ribbon connector up using a spudger.
Remove the ribbon cable from the connector.
