Ga door naar hoofdinhoud
Onda V701 Front- Facing Camera Replacement
Wat je nodig hebt
  1. Onda V701 Front- Facing Camera Replacement, Back Panel: stap 1, afbeelding 1 van 3 Onda V701 Front- Facing Camera Replacement, Back Panel: stap 1, afbeelding 2 van 3 Onda V701 Front- Facing Camera Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Front- Facing Camera Replacement: stap 2, afbeelding 1 van 3 Onda V701 Front- Facing Camera Replacement: stap 2, afbeelding 2 van 3 Onda V701 Front- Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Front- Facing Camera Replacement: stap 3, afbeelding 1 van 2 Onda V701 Front- Facing Camera Replacement: stap 3, afbeelding 2 van 2
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Front- Facing Camera Replacement: stap 4, afbeelding 1 van 2 Onda V701 Front- Facing Camera Replacement: stap 4, afbeelding 2 van 2
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Front- Facing Camera Replacement: stap 5, afbeelding 1 van 3 Onda V701 Front- Facing Camera Replacement: stap 5, afbeelding 2 van 3 Onda V701 Front- Facing Camera Replacement: stap 5, afbeelding 3 van 3
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: stap 6, afbeelding 1 van 2 Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: stap 6, afbeelding 2 van 2
    • Gently pry the front-facing camera away from the back panel using a spudger.
  7. Onda V701 Front- Facing Camera Replacement: stap 7, afbeelding 1 van 2 Onda V701 Front- Facing Camera Replacement: stap 7, afbeelding 2 van 2
    • Flip the gray locking tab of the ribbon connector up using a spudger.
    • Remove the ribbon cable from the connector.
  8. Onda V701 Front- Facing Camera Replacement: stap 8, afbeelding 1 van 1
    • Remove the front-facing camera assembly.
Conclusie
Bradley Huber
366 Reputatie
3 handleidingen geschreven
Colorado Springs, Team 4-6, Panko Spring 2015 Lid van Colorado Springs, Team 4-6, Panko Spring 2015
UCCS-PANKO-S15S4G6
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 9
Altijd: 255
