Ga door naar hoofdinhoud
Omaker M4 Battery Replacement
Wat je nodig hebt
  1. Omaker M4 Battery Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Battery Replacement: stap 2, afbeelding 1 van 2 Omaker M4 Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Battery Replacement: stap 3, afbeelding 1 van 2 Omaker M4 Battery Replacement: stap 3, afbeelding 2 van 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Battery Replacement: stap 4, afbeelding 1 van 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Battery Replacement: stap 5, afbeelding 1 van 2 Omaker M4 Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Battery Replacement, Battery: stap 6, afbeelding 1 van 3 Omaker M4 Battery Replacement, Battery: stap 6, afbeelding 2 van 3 Omaker M4 Battery Replacement, Battery: stap 6, afbeelding 3 van 3
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Carlos Pernia
170 Reputatie
1 Handleiding geschreven
USF Tampa, Team 2-2, Sullivan Spring 2016 Lid van USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
3 Leden
2 handleidingen geschreven
Één opmerking
What battery is required for this though? Is it easily found on amazon?
Mohsin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 1,330
