Ga door naar hoofdinhoud
Olympus VR-350 Power Button Replacement
Wat je nodig hebt
  1. Olympus VR-350 Power Button Replacement, Front Plate: stap 1, afbeelding 1 van 2 Olympus VR-350 Power Button Replacement, Front Plate: stap 1, afbeelding 2 van 2
    • Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
  2. Olympus VR-350 Power Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 4mm screws from the bottom of the camera with a Phillips PH000 screwdriver.
  3. Olympus VR-350 Power Button Replacement: stap 3, afbeelding 1 van 3 Olympus VR-350 Power Button Replacement: stap 3, afbeelding 2 van 3 Olympus VR-350 Power Button Replacement: stap 3, afbeelding 3 van 3
    • Use the plastic opening tools and your fingers to pry the front plate from the camera.
    • You might need to open the battery cover to remove the front plate.
  4. Olympus VR-350 Power Button Replacement, Back Plate: stap 4, afbeelding 1 van 2 Olympus VR-350 Power Button Replacement, Back Plate: stap 4, afbeelding 2 van 2
    • Use your fingers to pry open the back cover.
    • When you remove the back of the camera, the button membrane might fall out. Don’t lose this sheet.
    • The LCD screen is connected to the body of the camera by an orange ribbon cable. Don’t pull this ribbon cable out.
  5. Olympus VR-350 Power Button Replacement, Power Button: stap 5, afbeelding 1 van 2 Olympus VR-350 Power Button Replacement, Power Button: stap 5, afbeelding 2 van 2
    • Remove the silver panel from the top of the camera.
  6. Olympus VR-350 Power Button Replacement: stap 6, afbeelding 1 van 1
    • Flip the silver panel over. The power button is the smaller button covered by a metal backing.
  7. Olympus VR-350 Power Button Replacement: stap 7, afbeelding 1 van 1
    • Pull the metal backing away from the silver panel.
  8. Olympus VR-350 Power Button Replacement: stap 8, afbeelding 1 van 1
    • Push the power button down and out of the silver panel with your finger.
Conclusie
Adri
456 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-3, Leahy Winter 2015 Lid van USF Tampa, Team 1-3, Leahy Winter 2015
USFT-LEAHY-W15S1G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 19
Altijd: 1,506
